hello
I want to use the bl3 as surround speakers on the ceiling above the couch as the same time with the bl9 (4 meters back).
Both will be plugged on the same powerlink splitter.
Is it an issue for the bl3 if I use select "beolab 9" for the type of speaker on the sound menu ?
I will use this setup only for the 5.1, I will use a wireless controller in order to cut the electric power going to the bl3 for audio (speaker 4 listening).
Thanks in advance for your advices.
Best regards
olivier
4 beolab 5, beolab 9, beolab 10, beolab 5000, beolab 8000 mk2, beolab 6002, beolab 3500, beovision 7 55 mk2, 2 beovision 11 46 mk4, beotime, beosound ouverture, beosound essence, beoplay A8, beomaster 900 RG de luxe and the collection continues...
