Beosound 9000 Mk II
This post has 9 Replies | 3 Followers
mickoz1
Posts 4
mickoz1 Posted: Tue, Nov 21 2017 11:28 AM
Dear B&O Experts,
This post is a request to you if anyone can direct me to how I can source a new CD Driver for my Beosound 9000 MkII. My machine has "died" in that the CDs no longer rotate and I get the PAUSE message. I have read that this is a problem others here have posted in the past and that it is probable that the laser is finished and a new CD Driver is needed. My problem is that I have learnt from the B&O folks here in Zurich that that the replacement part is no longer made/supplied by B&O!! That now renders my Beosound 9000 pretty much useless :-(
Any suggestions where I could pick up a new CD Driver much appreciated.
Kind regards to all.
Michael
ipaul
Posts 422
ipaul replied on Tue, Nov 21 2017 12:05 PM
Hi, i coincidentially see you post:)
the key question is: are you able to repair yourself ?
if you do not have the experience/skills, do not try.
either way, i may have a solution (i am n CH in December) pls send me a PM.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Tue, Nov 21 2017 12:29 PM
mickoz1:
Dear B&O Experts,
Michael
Well, there should still be parts for the MK3 versions of the Beosound 9000 available. The MK2 can be upgraded with the new MK3 version. Try and ask your dealer and give them this information.
/Jacob
Weebyx
Denmark
Posts 1,213
mickoz1:
Dear B&O Experts,
Michael
/Jacob
mickoz1
Posts 4
mickoz1 replied on Tue, Nov 21 2017 12:31 PM
Thanks for this suggestion. I discussed the Mk III replacement part and the B&O folks said that it was not possible to use this replacement part as the mechanisms between the Mk II and the Mk III are different.....?
Peter
Siemianowice Sl., Poland
Posts 111
Peter replied on Fri, Nov 24 2017 11:16 AM
Mickoz1, try at least to clean laser lens, sometimes it helps
mickoz1
Posts 4
mickoz1 replied on Fri, Nov 24 2017 11:41 AM
Many thanks for the suggestion. How do you clean the laser lens exactly? Its in the moving arm somewhere, right? Many thanks!
marexy
Posts 710
marexy replied on Fri, Nov 24 2017 12:03 PM
can you take a photo of laser that you have...
mickoz1
Posts 4
Is this what you mean?  Sorry am not a techy with this stuff. Cheers
marexy
Posts 710
marexy replied on Fri, Nov 24 2017 12:35 PM
mickoz1:
Than it's only official B&O service best for you.
Page 1 of 1 (10 items) | RSS
