Faulty Beoplay A8 remote?
thorne
Posts 315
thorne Posted: Thu, Sep 6 2012 9:10 PM
Hi
A weird one this, I can use the included remote to change volume but it will not change to the next or preceding track.  A light on the A8 indicates the command has been received, but it does not respond
I hope there is a simple solution!
thorne
Posts 315
thorne replied on Thu, Sep 6 2012 10:42 PM
Further to my original post, I now discover I cannot change tracks using the controls on th A8 itself
Everything else works perfectly
thorne
Posts 315
thorne replied on Sat, Sep 8 2012 3:14 PM
Problem solved.  Apparently it is an inherent problem if your itunes library is on a Mac or PC.  If you stream from, say, an iPad, the controls work perfectly
Chris Harrison
Peak District
Posts 381
The remote turns the volume up when streaming music from a mac/ pc.
I have an original Beosound 8. If you want to skip the track, download 'Apple Remote' app for iPhone/ iPad/ iPod Touch and skip the track from there - really easy but any problems, let me know. I'll talk you through it.
Beosound 8, Beotime, Beocom 4, Beo 5, Lutron Rania, MacBook 15" (Mid 2015), iPad Pro, iPhone 6S, B&O Play H3, Beolit 12, Form 2, A8 Headphones, B&O Play A1, B&O Essence
thorne
Posts 315
thorne replied on Thu, Sep 13 2012 5:49 PM
Yeah, thanks, that's what I have done.  It's just that I started from the premise that if there is a skip track feature on the Beoplay A8, then it ought to work!
Page 1 of 1 (5 items) | RSS
