Hello all!
So I have stumbled across a used BV11-40 for sale locally. I really should not spend the money, but I am thinking that it is rare that one comes up for sale in my area. If can scrape the funds together is there anything that I need to look for with these BVs? Any common issues? Also it comes with a wall mount, is it possible to mount the BV to a table stand easily?
Thanks in advance for any advice!!
PS: I am still desperately searching for some feet for my BV 8-32 as well! If anyone has them...
Beosound 9000 MK III, Beosound Century, Beogram 5005, Beolab 8000, Beolab 5000, Beolab 4000, Beolab 5, Beovision 8, Beovision 10, Beovision 5, Beoplay A2, Beoplay E8, Beoplay H6.
Great TV. Mine has the motorised wall mount. It's a hinge to the left or right of the TV, so make sure that the TV can swing in the right direction for your room. If converting to a floor stand you will need some replacement rear panels..... and I don't know whether converting to a motorised floor stand is a possibility. I doubt that there is a table stand option as opposed to a floor stand.
Graham
