Activating Tape 2 on Beomaster 7000?
Lennart Hildeman
Scania
Posts 81
Silver Member
Lennart Hildeman Posted: Sun, Dec 3 2017 7:50 PM
Beocord 2400 wants to sign into my system, and it seemed logical to connect it to the Tape 2 at the back of the BM7000, but I do not know how to activate this. I have Beolink 7000, Beo 4, and Beolink 1000. If you have any experience of this, I would much appreciate your advice. The manual for the BM7000 is not very helpful.
Regards
Lennart
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Dec 3 2017 8:12 PM
Shift A.Tape on the Beolink 1000 and just add Tape 2 to the menu on the Beolink 7000. Not remote though.
Peter
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Dec 3 2017 8:15 PM
Have you got the Beolink 7000 user manual?
Peter
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Dec 3 2017 8:17 PM
You can add Tape 2 to the Beo4 as well and use the List system. Have had the full 7000 system - the Beolink 7000 is the best remote B&O ever made. The Beolink 1000 is the most sturdy! All engineers for B&O used to carry a BL1000!
Peter
Lennart Hildeman
Scania
Posts 81
Silver Member
Yes, I have it on the screen right now.
Lennart Hildeman
Scania
Posts 81
Silver Member
I do not understan ”not remote though”. Leafing through the LIST sys on Beo4 now, and not quite sure what to choose. Add AV2?
Lennart Hildeman
Scania
Posts 81
Silver Member
That worked. The BC1000 is sturdy, I agree; a greattool, indeed. I thank you for your help.
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Dec 3 2017 10:32 PM
The Beocord 2400 does not have Datalink so will not be controllable with the remotes. I used to run my 7000 system with a Beocord 7000 and a Beocord 5500. That way, I could use both in my link rooms.
Peter
Peter
Earsdon
Posts 11,991
Peter replied on Sun, Dec 3 2017 10:34 PM
On the Beo4, there is an A.Tape 2 option, though N.Music is actually the same command!
Peter
Page 1 of 1 (9 items) | RSS
