Beovox 1001 removing metal frets
This post has 1 Reply | 0 Followers
beo3000
Posts 109
beo3000 Posted: Sat, Dec 9 2017 5:29 AM
I have nice set of Beovox 1001 here I want to open them up for a recap does anyone knows how the frets come off I don't want to damage them
Thanks Smile
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sat, Dec 9 2017 9:13 AM
Not easy.
You will have to, very carefully, ease the plastic surround about 4-5mm away from the wooden cabinet at one end of the speaker.
That is one end and partway down the two sides.
Enough to remove one piece of the plastic surround.
Then you can pull out the metal screen.
It's very difficult to do without leaving any marks to the wood.
Use a sharp spatula or other suitable tool and work gently and patiently.
Page 1 of 1 (2 items) | RSS
