Line out. If I remember correctly it has volume adjustment
Being picky, but I think that the volume controlled output is actually called 'PRE OUT' on the BM5500. The connectors are just below the passive speaker sockets.
But have a look here also: http://archivedarchivedforum2.beoworld.org/forums/p/38944/323344.aspx
Hi Pat,
Yes, Guy is correct. You should see a pair of RCA/phono sockets on the rear panel of the Beomaster marked “Pre-Amp Out Left/Right”, the following cable will connect from the pre-out sockets on the Beomaster into the “Line” sockets of the Beolab 8000 speakers:-
http://soundsheavenly.com/line-in-connection/6-av-processor-pre-amp-sonos-to-beolab-rca-line-in.html
Please set both speakers to “Line” mode using the small switch next to the input sockets.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
