I have wired my 2300 BeoSystem into my Masterlink system....... I received the cables from Steve yesterday and was anxious to get everything up and running. I have a Beosound 4000 as a master and a few passive and a Beolab 3500 hooked into my system....
Here goes from what I was told with the proper cables which is a cable from the 2300 Beosystem Aux port to a 1612 plugged into the Powerlink socket. I should be able to plug the 1612 into my Masterlink system and be good to go. I did set the active to option 4 and when I hit A.Aux in my BEO4 remote LIST I get no music???? What am I doing wrong? I have tried to Link to RADIO. But no luck with any sound....... What am I doing wrong????
How do I LINK to RADIO?
AM I correctly setting the 1612 to Option 4?? How do I do this?
Like I said I have a BEO4 remote and am really lost here..
Any help???
The BS2300 connection should be to the AUDIO AUX LINK socket of the 1612.
Yes I have the unit connected to the Audio Aux Link port on the 1612
Why does that happen to me!!!!
striker27: Why does that happen to me!!!!
If you get frustrated with the speed of response, perhaps you hit the POST button more than once - this often happens!
But back to your question. Haver you had a read of this post in the archived forum? http://archivedarchivedforum2.beoworld.org/forums/t/24667.aspx
I think the over-riding problem could be that BC2300 is too old a system to be set up as a 'slave' in a masterlink network.
I was emailing Steve at Sounds Heavenly he gave a solution to use a B&O active unit. Sadly at present I only have a 1612 not a 1638. Hope fully I can still get this all set up...
