Beosound 9000
MRICO
Posts 4
MRICO Posted: Fri, Dec 8 2017 2:36 PM
Hi, I have a Beosound 9000 which have the laser ready broke, and I need a part (image below) to fix it. Does any one might suggest where to find it?
Many thanks for your help.
Mauricio Rico
MRICO
Posts 4
MRICO replied on Fri, Dec 8 2017 3:44 PM
Sorry image was not attached. The CD laser reader item number is:
8420001
14-04-14
CD mechanism BeoSound 9000
Regards.
Peter
Siemianowice Sl., Poland
Posts 111
Peter replied on Sun, Dec 10 2017 11:25 AM
Could you tell on which page of service manual your part numer is shown ? For me it seems that your Beosound 9000 is an older version.
The best way is to picture the laser mechanism, it should have a label with type and number
MRICO
Posts 4
MRICO replied on Mon, Dec 11 2017 6:48 PM
Many thanks Peter for your prompt answer, Ye it is an older version, I bought it more than 12 years ago. I`ll ask to the B&O technician for the part number to share with you, to see if you can help me to find it out.
Best regards.
Page 1 of 1 (4 items) | RSS
