Beocord 7000 Play Problem
This post has 3 Replies | 0 Followers
Manbearpig
Posts 908
Manbearpig Posted: Thu, Dec 14 2017 9:03 PM
Dear members,
unfortunately, the play button on the front panel of my Beocord 7000 only works when the Beocord loader is open. As soon as it is closed I am unable to push the metal part deep enough... How can I fix this issue?
Thanks!
Kai
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Dec 14 2017 10:08 PM
The right side of the front bar hits on the cabinet side before activating the switch.
Arrange the top cabinet to sit a little further back (or the drawer to not close quite as far back.
Manbearpig
Posts 908
Manbearpig replied on Fri, Dec 15 2017 12:46 PM
Thanks so much, Martin. Problem is that the Beocord sits at the very bottom and getting it out from where it is will end up being quite a mess. Is there a possibility to adjust the drawer without having to remove or adjust the top cover?
Thanks!
Kai
Dillen
Posts 13,191
Dillen replied on Fri, Dec 15 2017 2:36 PM
Manbearpig:
Thanks!
Kai
No.
Page 1 of 1 (4 items) | RSS
