Hello again brand colleagues,
Some time ago I bought a Beocenter 2 which had a damaged aluminium sliding door, basically was out place and flat cable cut.
After reinstalling the door and new cable, the systemcomes to life, panel, doors and buttons, start opening and closing but with the famous "no lights and immediate shut up" so surfing our forum found the answer but after changing motor rubber the system still refuses to run as suppossed.
Now after loading the CD, system close and reopen partially the wings, no running disk and no lights.
If I remove the panels and use a magnet on the left one the disk spins and sounds but the loading operation, open and immediately close persists.
I believe it should be a mechanical problem or something was not properlly assembled after changing the motor rubber.
Messages displayed are IIC1_2_ERROR 01018C00 - 01012200 / 010118801
Any ideas or advise before visiting B&O after sales service.
