Good evening, gentlemen--
I was wondering if anybody is familiar with the BeoSound 9000 device and whether it's easy to use it here in the US with the European guts inside of it.
So basically, are these devices hard to convert or do they need one of those big converter boxes?
Picture of the player attached below:
https://imgur.com/a/6fsaK
BS9000's power consuption is 15W so the converter box doesn't have to be big (even 55Watt would be enough) https://www.walmart.com/ip/VCT-VX55-Voltage-Converter-55-Watts-for-Using-220V-240V-Foreign-Products-in-Canada-with-110-120-Volts/514510003
