Beosound 5 Sound Settings not displaying
wogga383
Posts 41
wogga383 Posted: Thu, Jan 4 2018 6:52 PM
getting frustrated with this so any advice would be welcome.
i have a Beosound 5 connected via Powerlink to a pair of BL8000 mk2. I cannot get the sound settings to display? I need to change the default volume on start up. The BS5 is set to Audio Master option 1. The volume blue line indicates maximum when I move the dial.
The only other connection is Masterlink to a BL3500. All operates ok, I have read that I need Powerlink speakers to display the sound settings so with the BL8000 I should be ok?
I have had this setup from New for about 6 years.
My Beo6 remote has no impact on changing the settings either.
any thoughts appreciated.
Regards.
Mr 10Percent
So West, Its Now East
Posts 591
I rusty on the settings. Will do a bit of homework on this tonight when I have access to the machine. Reply further if I can.
A full blue volume bar suggests you are in option 2 as a audio master to a video master? ??
Check your settings in the maintenance menu (align mode to settings. >> << go). Check roles and options. Option 1, AM master.
wogga383
Posts 41
Thanks 10% I can confirm unit is set to audio master and option 1. I tried all other options for fun, still no sign of the sound settings and volume indicator shows max. Audio master off is no different.
Page 1 of 1 (3 items) | RSS
