ive just got another Beoremote One for my Beosystem 4, but it is different to my existing Beoremote One in that the old one had three MyButtons, while this one has Netflix and Prime buttons.
is there a way I can re-assign these two buttons so I can get back three MyButtons on this remote? The standard way of pressing and holding doesn’t seem to work on these, but works fine on the single MyButton between TV and Music.
frog:Hi, ive just got another Beoremote One for my Beosystem 4, but it is different to my existing Beoremote One in that the old one had three MyButtons, while this one has Netflix and Prime buttons. is there a way I can re-assign these two buttons so I can get back three MyButtons on this remote? The standard way of pressing and holding doesn’t seem to work on these, but works fine on the single MyButton between TV and Music.
Beolab 50, Beolab 8000 x 2, Beolab 4000 x 2, BeoSound Core, BeoSound 9000, BeoSound Century, BeoLit 15, BeoPlay A1, BeoPlay P2, BeoPlay H9 3rd Gen, BeoPlay H6, EarSet 3i, BeoVision Eclipse Gen 2 55", BeoPlay V1-40, BeoCom 6000 and so much else :)
I would, but I bought it off eBay. So.... no chance then?
frog:I would, but I bought it off eBay. So.... no chance then?
Well the image was a library pic of the non-Netflix/prime one.... hate to have to return though.
Mikipedi4 on Twitch: https://www.twitch.tv/mikipedi4
Mikipedia on Intagram: https://www.instagram.com/mikipedi4/
Old: Beosound 9000 mk3, Beolab 3's, Beovision Eclipse, Beolab 1's, Beolab 2, Beovision 10-46, Overture 2300, beolab 8000's, Beolab 4000's, Beovision avant 32" etc. etc.
Thanks, I was aware of that. Just wanted to know if I could get more than one MyButton on the new remote. Seems not.
frog:Thanks, I was aware of that. Just wanted to know if I could get more than one MyButton on the new remote. Seems not.
