Beocord 5500 Tape deck spindles slipping
Tiger18
Singapore
Posts 4
Tiger18 Posted: Thu, Jan 11 2018 1:10 AM
Hi Fellow Beocordians, Just happen to lay my hands on a Beocord 5500 from a local seller. The deck seems to be in quite a good shape. However, I notice that, when I try to play, FF or REW a cassette, when the tape spindle hubs turn, they give like a gear slipping impression. Any suggestions?
Would the Tape transport mechanism belt be the culprit or any issues with the deck mechanism?
Secondly, where can I order the belt if it is indeed the issue?
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Thu, Jan 11 2018 12:24 PM
If the belt(s) were never replaced, that would be the place to start.
I can supply correct belts. Email or PM me.
Tiger18
Singapore
Posts 4
Tiger18 replied on Thu, Jan 11 2018 12:59 PM
Thanks for the reply, Martin.
Yes, from the interiors, it seems, the unit was never opened and the belts never changed.
Tiger18
Singapore
Posts 4
Tiger18 replied on Fri, Jan 12 2018 12:28 AM
Hi Martin,
How to email or PM you? I tried using the forum by clicking against your name and sending an email to you. Not sure though, if you have received it?
Regards
Dillen
Posts 13,191
Dillen replied on Fri, Jan 12 2018 8:07 AM
I have sent you an email.
Page 1 of 1 (5 items) | RSS
