Hi all,
has someone tried to connect a beosound 5 to a standard PC?
My beomaster is broken and before I put energy into the system I would like to ask you for advice.
I thin it should be possible to connect the beosound 5 to a PC. It is a display with a USB device.
It would be great to get your feedback and experience?
Thanks!
