Dear all,
Please kindly inform me whether the cartridge MMC 20EN should be connected a cable to MM or MC position on the amplifier.
I have recently purchased BeoGram 4004 from an audio shop in our country.
Your prompt reply would be highly appreciated.
With best regards
Hans Moon
Hi, Hans,
the MMC are designed for a MM input
Chris
Dear Chris,
Thank you very much for your prompt reply.
Happy New Year!
Hans
It is actually a moving iron cartridge which uses the MM input but you may find that the output is lower than most moving magnet cartridges. This means the volume needs turning up an extra notch. I think some Ortofon cartridges use a similar system.
Peter
Dear Peter,
Many thanks for your information.
best regards
hans
