BeoSound 1
Paul47
Posts 1
Paul47 Posted: Mon, Jan 15 2018 12:11 PM
re: BeoSound 1,CD/radio, serial number 15309777
simple question
Does this model have an on/off switch?
How can I switch it off from standby?
thanks
lawrencejmcook
Posts 742
There is no mains switch on the device. You need to unplug it from the wall, or switch it off at the wall socket, or buy a mains lead with an inline switch and switch it off there.
Kind regards,
Lawrence
Opman
Wilmslow, Cheshire
Posts 443
Opman replied on Mon, Jan 15 2018 9:00 PM
If you intend to switch off power completely you will need to think about whether or not to deactivate the PIN. If you don't you will have too unlock every time you restore power.
Regards
Opman
Page 1 of 1 (3 items) | RSS
