Beogram 1700 - tonearm withdrawing direcly fter contact with record, then "hanging" in starting position
This post has 3 Replies | 0 Followers
Dejan1977
Posts 4
Dejan1977 Posted: Sat, Jan 27 2018 8:45 AM
Hi!
I recently bought a Beogram 1700 along with a Beosystem 8500.
The Beogram 1700 has a few problems:
1) After having pressed 33/45-button and later aligning with a record, the tonearm directly withdraws to starting position, no sound gets played
2) The tonearm "hangs" in starting position, lowered down. When moving towrds a record risking to scratch the record both when aligning and withdrawing.
Anyone know why this happens and how to fix it?
Best regards!
Dejan Matic
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Sun, Jan 28 2018 11:32 AM
Needle OK?
Tracking force set correct?
Dejan1977
Posts 4
Dejan1977 replied on Sun, Jan 28 2018 3:19 PM
Hi!
Needle is ok, as far as i know.
How do I set the tracking force?
/Dejan
Dillen
Posts 13,191
Dillen replied on Sun, Jan 28 2018 3:54 PM
The tracking force is set using the slider next to the counterweight and according to the cartridge/needle type (look in the user manual).
A tracking force gauge would tell you the actual force and allow you to verify the setting.
Page 1 of 1 (4 items) | RSS
