Hi Everyone,
I have one more question about the Beomaster 3400 — so it is now beautifully restored and works great. I hooked it up to a pair of P45’s for the front (which needed a lot of work as they must have been stored in a damp place) and P30’s for the rear and the result was magnificent.
Howeever, it turned out during the repair that the horizontal potentiometer controlling the balnce between speakers 2 and 4 (rear) has a broken path. The people repairing it fixed with some conductive glue, but this fix wont’ last forever. So my question is are the 2 horizontal sliding potentiometers in the Beomaster 3400 the same as the sliding potentiometers in the Beomaster 2000? The second one is much easier to find, of course...
I would greatly appreciate any information!
Best,
Piotr
The Balance potentiometers are the same - but they are not identical to the volume/bass/treble!The balance potentiometers are working their two channels in reverse with zero resistance at the potentiometer center position.
I am sure I can find a good used correct potentiometer in the dungeons.
Dear Martin, thanks a lot! I just sent you an email through BeoWorld.
I have to say I am very happy with the quadrophonic sound the Beomaster produces! It has a built-in SQ demodulator, and I listened to a couple of classical music LPs on it — I had the impression that walls and speakers dissapear and that I’m sitting in a philharmonic. Quite amazing!
