Hi all, I recently purchased the E8 earphones and have been happy with them.
I read today on the support page for Beoplay that you should only charge your E8 earphones once every 2 days or so - this means only placing the earbuds into the charger once every 2 days or so.
It also says to keep the earbuds in a dry cool environment when not charging.
I am just wondering how other E8 users store their buds when they are not charging.
I am too afraid that they'll go missing if they are not stored properly..
andy_j -- Can you post the URL where you read this? Sounds like an odd thing for a manufacturer to recommend. Every rechargeable product I've owned have recommendations based on battery usage / drainage and recharging intervals, not based on time (i.e., "every 2 days").
I just purchased my E8 pair over the holidays and have had dropout problems between the two earpieces along with odd iPhone App connection issues. Sound is good, but I'm not happy about the overall wireless signal quality so far.
I'm honestly considering sending these back and just settling for the Apple EarPods. Sounds is subpar, but at least they have solid, redundant wireless connectivity.
