CD7000 drawer speed
seethroughyou
UK
Posts 999
seethroughyou Posted: Wed, Jan 31 2018 7:30 PM
Is there any way to adjust the speed at which the cd drawer opens and closes?
My CD player has either been serviced or is faltering but the drawer shoots out disturbingly fast. Too fast.
Present: BL90, Core, BL6000, CD7000, Beogram 7000, Essence Remote.
Past: BL1, BL2, BL8000, BS9000, BL5, BC2, BS5, BV5, BV4-50, Beosystem 3, BL3, DVD1, Beoremote 4, Moment.
Weebyx
Denmark
Posts 1,213
Weebyx replied on Wed, Jan 31 2018 7:58 PM
seethroughyou:
Have you checked if the leaf contact that detects open/closed is correct adjusted and has been cleaned and has good contact ? Sometimes if the processor cannot determine the state of the drawer, bad things happen. I have seen this behaviour once :) Fixed by cleaning and adjusting contact.
Without power you can manually open/close the drawer, and gently bend the outer contact pins back into position so the middle reaches the correct.
/Jacob
Page 1 of 1 (2 items) | RSS
