Hello,
for the long time, I still try to find covers for my Beolab 8000s. But I think it's not possible, there's nothing on eBay, forums, anywhere.. Especially when I try to find it in white color.
But in the Beoshop there are (supposedly) brand new one (including in white) for Beolab 8002.
How large diferences there are? Of course, at the first sight I see other solution of the diode. But it can be modified. But what about dimmensions, or handles?
Thank you all for your help!
Denis
I dont know the answer to your problem. However, if you are trying to replace them because the fabric is damaged, simply buy some acoustic fabric and put it over the speaker grill.
Thank you for your reply.
It would be the best way, I know, but problem is that plastic constructions on my 8000s are damaged (broken in several places). And there's no way how to fix it..
You Can buy Them here:
http://www.bremdal-radio.dk/webshop/brugt-b-og-o/lyd/tilbehør/beolab-8000-frontstof-sort/
And in white here:
http://radioogtveksperten.dk/tilbehoer-44/frontstof-104/beolab-8000-105/beolab-8000-hvidt-frontstof-ombytning-987.html
Søren
Thank you Soren!
I never find it on this site. If this website is real and no fake (I don't have any experience with Denmark e-shops - but in this case it's manufacturer country), I'll try to buy it and I hope that my 8000s will have a new covers as soon as possible
Hello guys,
so, yesterday I got the package with new covers. Soren, thank you for your help!
But.. Is it normal how dark is it? It's more like grey than white. But OK, that's new covers, my old covers had a good fabric, but the plastic construction was broken.
Guys,
I would like to take this opportunity and ask all of you if anyone know where to find other parts to fix my 8000s, because the seller (of my 8000s) was a cheater and it's necessary for good condition. I didn't know how bad it was..
And last question. Are the top parts (round chrome covers on the top of the 8000s) changeable? Because on the one loudspeaker is this cover in the bad condition and if I ever find it, I don't know if I can replace it..
Thank you for every tips and advices!
Looks great!
Sources: 2x Beosound Moment • 4x Beosound Essence Mk II Speakers: 3x Beolab 8000 • 2x Beolab 6000 • 2x Beolab 3 • 3x Beolab 2 Integrated: 1x Beosound 2 • 1x Beosound Level • 4x BeoPlay M5 • 1x BeoPlay A6 Control: 16x* Essence Remote • 1x Beoremote Halo
* Yes, really! 🤦♂️
Thanks!
