Is it possible to make the Beoplay V1 stop reacting on the audio buttons on the remote so I can have a stand alone audio system in the same room?
I have tried to remove alle instances of the audio buttons (radio, CD, A.MEM) from the source list but the TV keeps turning on when i hit one of these buttons.
Is there an option setitng I am missing?
Try setting the devices to different options.
Hej
If Your BV is set to Danish language.... Go to “opsætning” — “produktintegration” —-VM-Indstillinger” then choose “1”
Søren
Thank you that was just the info I needed. Couldn't find it in the manual. It only describes settings for two TV's in the same room
