Hello!As written in an other thread I got a new Avant NG; problem: the TV does not find any satellite channels; I am feeding it with "unicable" standard - with the old (new) Avant 75 everything was fine! Now I can enter every detail within the search menu but the TV doesn't find any satellite - obviously the search function is not starting -> the grew bar does not change to white...
Anyone an idea? (I do not want an external sat receiver - would be the last option).
Best Regards
Elmar
maybe anyone with the Code for the service mode/menue? I hope that I could set more then the given preferences....
Problem solved:
unicable: you have designated user bands with a certain frequency to use
In my case: user band 2 and 3 - the BV starts its List to enter user bands with 0/zero! I Tried BV 0 = user band 1; BV 1 = ub 2 and so on and it worked
best regards elmar
