MMC4 on Beocenter 7007: Distorted sound
This post has 12 Replies | 0 Followers
Bojdejong
Posts 12
Bojdejong Posted: Fri, Jan 5 2018 3:31 PM
Hi all,
I've recently bought a MMC4 cartridge online, which was supposed to be in good condition. But once I plugged it into my Beocenter 7007 the sound is very distorted. The seller says it's because of the needle pressure, but I've put that on 1.5 as stated in the specs, but the sound is still distorted.
Picture below with a close up. He told me the cartridge is in good condition, but looking at it up close I don't get the feeling it's in good condition. What do you guys think?
1
Saint Beogrowler
Saint Paul
Posts 780
It could be dirty
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Jan 5 2018 7:43 PM
I agree. It could be dirt, but the cantilever looks a bit offset to the side.
To judge the stylus, a close-up of the stylus from the side would've been better.
Peter
Earsdon
Posts 11,991
Peter replied on Fri, Jan 5 2018 9:53 PM
the plastic cover looks not straight - I guess this in not as advertised - if cheap, re-tip it. If expensive, return.
Peter
Bojdejong
Posts 12
Thanks to all for the answers. Below is a side view, hopefully that's detailed enough?
Side
Thanks,
Boj
Hiort
Sweden
Posts 2,895
Hiort replied on Tue, Jan 9 2018 2:07 PM
Think a better closeup is needed, but form this picture the needle look a bit "rough". Dirt?
Dillen
Posts 13,191
Dillen replied on Tue, Jan 9 2018 2:47 PM
I agree, the tip looks very dirty.
Bojdejong
Posts 12
Thanks both. Any tips on how to clean the tip?
Bojdejong
Posts 12
Saint Beogrowler
Saint Paul
Posts 780
Back to front with a cartridge brush for light dust. Gentle vertical dip onto a magic Mr Clean Magic Eraser without detergent works nice. Soundsmith recommends a dip into Blue-tak and that works nice too. I'd avoid liquid solvents if possible in order to preserve the suspension compliance and stylus adherance.
Many dedicated products are sold for this, Google and YouTube will be your friend here.
AudioOrigin
Posts 53
As peter said if expensive just return it lots of eBay sellers sell junk,
Take a look over here for all the options offered by audio origin for repair
http://www.audio-origin.co.uk/retipping-stylus.html
or here to go through eBay
https://www.ebay.co.uk/usr/audio-origin?_trksid=p2047675.l2559
You can send it to me to get repaired, happy to clean it and check it on the microscope but it will most likely need to be repaired the angel of the cantilever does not look correct in that image, if it just needs cleaning I can return it for the postage cost.
audio.origin.uk@gmail.com
Alistair
MediaBobNY
Greenwich Village, NYC
Posts 1,106
AudioOrigin:
Here's a good MMC-4.  The cantilever drooping on yours is a sign of suspension failure.
W.Frankenberg / Gandalf
Heilbronn / Germany
Posts 290
on your first picture the needle seems not in the center position of the Cartridge, needs repair!
On the second Picture (look from the side) the diamond looks very bad, dirty or broken?
wilfried
Page 1 of 1 (13 items) | RSS
