I am on the BETA Track of the Bang & Olufsen App. I have noticed, that since 1.6.0 the Beta Track App is not up to date. In the "normal" App-Store the version is 1.6.1.
Is the public beta track closed?
Mirco
Thanks MircoHH, I didn’t realize it. Let’s wait for the next feature update to see if it’s the general version or the public beta that benefit of it first.
diisign.com
BeoNut since '75
It seems there is a new beta version (1.7).
Y'all also might have received a re-notification of 1.6 on Friday?
Seems that was a false dawn, and now we have a new version to test !
However it requires a login !
I have no idea which login I have to use ... presumably my standard B&O login and not by Apple Developer's ID ?
Anyway I am sure we will sort it out ...
Change log says:
1. Tone touch
2. Video on loin screen ... well I can verify that :) I just can't get past it for the moment
However I have NO idea what Tone Touch is, however I am excited that it may be something completely new
elephant: Seems that was a false dawn, and now we have a new version to test ! However it requires a login ! I have no idea which login I have to use ... presumably my standard B&O login and not by Apple Developer's ID ? Anyway I am sure we will sort it out ... Change log says: 1. Tone touch 2. Video on loin screen ... well I can verify that :) I just can't get past it for the moment
Well I reset my password, and I am in, and now I will not see the lovely video again
And ... after some poking around ... I have no idea what Tone Touch is ???
Any ideas anyone ?
Livingroom: BL3, BL11, BV11-46 Kitchen: Beosound 1 GVA, Beocom 2 Bathroom: M3 Homeoffice: M3, Beocom 2 Library: Beosound Emerge, Beocom 6000 Bedroom: M5, Essence remote Travel: Beoplay E8 2.0, Beoplay EQ, Beoplay Earset
Hiort:Tone touch is the way you can tweak the sound in the Beoplay app. Works for the Beoplay devices.
Thank you & mbolo01
I had recalled the BeoPlay option ... I had "ass+u+me"d that they were bringing this sound shaping to all speaker types ... sadly (? perhaps ?) all my speakers are BeoLabs.
Unless I can add the A1 and/or the A2 to the App ... which I doubt !
