Just installing a new Virgin V6 STB. Connected to BeoPlayV1 TV
Which PUC should I download and where should I put the IR sticky on the front of the box so I can control it with the Beo4 remote
I would like to know the answer to this too! About to replace the old Virgin box with the V6 box and hoping that the Beo4 will still work.
I think that the new Virgin V6 box has an RF (radio frequency) remote rather than IR, hence the STB will not work. I think the V6 remote itself has an IR function, but that is just for controlling your TV.
But I may be wrong ...
Guy: But I may be wrong ...
I was!
Thank you folks!
