Beocenter 2600 - sound issues
Richjaffa
Posts 2
Richjaffa Posted: Thu, Mar 8 2018 10:27 PM
Hi - I've had the 2600 for a few years now - great sound.  I have got used to readjusting the volume slider to get both speakers working sweetly.  The right one can go silent on me.
Now I have a bigger problem - the volume fades right down and then back up all on its own and the volume slider does not behave as I would expect.
Can anyone advise please?  Thanks-  Richjaffa
ps - I don't believe in poltergeists...
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Fri, Mar 9 2018 6:16 AM
If both channels are affected at the same time, it could point to a common circuit, perhaps a voltage supply and/or regulator problem.
You could choose to clean the volume potentiometer while in there.
Richjaffa
Posts 2
Richjaffa replied on Tue, Mar 13 2018 10:59 PM
Hi Dillen - just cleaning the potentiometer did the trick.  I'd not had it apart before - very dusty and an ancient spiders web inside - little critters.  A blast of gas duster and a careful clean and its sweet as a nut.  Thanks. r
carlm21
Posts 3
carlm21 replied on Wed, Mar 14 2018 5:13 AM
good one
Page 1 of 1 (4 items) | RSS
