Hi
First time I have one of these (smells badly cigaret and has the color of it too).
I found 4 screw at the bottom but cannot find how it opens, do not have the service manual eather.
As I never force on anything, may be there is a trick ???
regards
patrcik
OK found it !!!! there are more around the speaker. did not take out the front of speaker right away
Hi. Did you manage to get the bottom off? If so how?
