Hello all!!!!
I am in the middle of my project which is no other than having music sources available through the house. After having successfully connected the living room with the bed room I am now trying to add my office. The setup is a bit complicated:
Living room
Beomaster 6500 to BLC via a beolink converter (1611)
BLC to beolink distributor (rj45)
Bed room
Beovision 6-26 to a beolink distributor (rj45) via a masterlink to rj45 cable
Office
Beolink Passive to beolink distributor via a masterlink to rj45.
Bedroom and Livingroom communicate perfectly. The office is not at all communicating.
BLC is configured as a video master. Beovision and beolink passive they are in opt 6
Any suggestions????
Tassos:Hello all!!!! I am in the middle of my project which is no other than having music sources available through the house. After having successfully connected the living room with the bed room I am now trying to add my office. The setup is a bit complicated: Living room Beomaster 6500 to BLC via a beolink converter (1611) BLC to beolink distributor (rj45) Bed room Beovision 6-26 to a beolink distributor (rj45) via a masterlink to rj45 cable Office Beolink Passive to beolink distributor via a masterlink to rj45. Bedroom and Livingroom communicate perfectly. The office is not at all communicating. BLC is configured as a video master. Beovision and beolink passive they are in opt 6 Any suggestions????
connect all the ML - connect the cables between the BS6500 and the T1611 also connect the ML cables to the link ML system - then, lug the mains of all devices and as the last to plug to the main the T1611.
Thanks for the fast response!!! the reason I have the BLC is cause I have a beosound moment and a beoplay v1 in my home theater room. Should I proceed as you suggested and connect last the BLC?
Tassos:hanks for the fast response!!! the reason I have the BLC is cause I have a beosound moment and a beoplay v1 in my home theater room. Should I proceed as you suggested and connect last the BLC?
Connect all ML devices as described connect the BLC to ML also.
Connect the BLC/Moment/V1 to router/switch.
This is how I have everything connected and was working like a charm! The only problem is the beolink passive. The rest works fine. Should I unplug from the mains all ML devices and the BLC and then connect them in a specific sequence?
