beogram 3404 start /stop/pause willnot responed
Harryr
Posts 2
Harryr Posted: Tue, May 1 2018 12:28 AM
to all ;  a Beogram 3404, I understand the sequence when first starting the unit , but after (turn) it will not start .
            i have the manual, but have never repaired a 3404 or it's similar models , Im a vintage tech repair person , but I don't know which way to approach this symptom.
 What I have done :
.   checked power supply ...Ok.
    cleaned all tach switches on control board(took each one apart)got unit to play by moving the (known as the lifting plate#1545).
when it did play set down was good ,tracked the length of Lp. rejected  But I could not get it to Stop or Pause during this time .
tanks in advance for your replys..
Page 1 of 1 (1 items) | RSS
