Hello Beoworld fellows, as STB Brackets started to sell VESA bracket for LG55C9 (even with a Stage holder, yay), I am wondering if for the 55" TV 7-32 floor stand would be okay and/or is 7/40 more massive and stable and hence recommended stand?
Or is the only difference actually one vs two vertical poles? Big thanks! :)
Thanks a lot, it helps to hear you‘re happy with the 7-32 stand. :)
