Will the Beo One BT work with a core? or indeed any audio product??
gordongofer:Will the Beo One BT work with a core? or indeed any audio product??
you need the essence remote for the core, although a One BT upgrade was promised last year.....
BeoRemote One BT has both BT and IR. I use the BT part on the tv and the IR on the audio and it works perfectly :-)
interesting
