Hello!
I would like to make some PL cables to set up my system (2500 & 7000 systems with AV7000 & a remote room). I cannot find the wire gauge/shielding for these cables. Perhaps this is covered elsewhere in the forums, but I have been unsuccessful with my searches.
Please share the needed gauge for PL cables. I can and do solder all the time, and do not wish to purchase ready made.
Thanks!
Jeff in Maryland
As far as I know PL cables can be of any gauge, because they don't carry high current.
However, depending on the lenght of the cable you may need thick ones.
Follow up: I did use Cat 6 cable, and it seems to be working very well. Cable is about 25' long.
