Beovision 11 and Deezer startup
This post has 9 Replies | 0 Followers
Master123456789
Posts 237
Master123456789 Posted: Mon, Apr 2 2018 6:03 PM
Dear forum
Are there some sort of work around to get Deezer a bit more stable (startups often fails) on Beovision 11? I have noticed at on mornings and early afternoons no problems. Always works.
I have also tried the app under webmedia, that is some times a bit better.
It can maybe help to turn to tv or radio and then try again - sometimes helps.
I can live with that the app is not that good designed, but that it won't start up is useless! I love that I can use the BV11 for everything tv-radio-music and have only turned to Deezer becouse it is on the BV11. So sad that Spotify have left.
Master123456789
Posts 237
Nobody that uses Deezer on a BV11 or Beoplay V1?
Hiort
Sweden
Posts 2,895
Hiort replied on Wed, Apr 4 2018 4:19 PM
I doubt that Deezer support that app anymore.
Master123456789
Posts 237
RIght now it cannot play
kallasr
Germany
Posts 2,562
kallasr replied on Wed, Apr 4 2018 7:34 PM
On Beosystem 4 it does not work Indifferent
Fansastic
The Hague, The Netherlands
Posts 768
Deezer on my V1 never was a good marriage. You better use the B&O app for playing Deezer music on the V1. Not sure if you need an additional Multiroom device for it. A M5 / A6 are the most economical choice for a multiroom upgrade. Works very well with the BV11/V1, the multiroom usability is great.
Hope this helps
Master123456789
Posts 237
Interesting, I will try that as soon as I got time. :) I could be an option.
vikinger
Vestri Kirkjubyr, UK
Posts 5,422
I used to use Deezer on my BV11, but only the free 'Radio' version. I haven't bothered with it for ages as I have alternative streaming sources, and Deezer went through periods in the past when it simply would not load beyond its home page.
This thread prompted me to take a look at it again. Unless I am mistaken the layout has completely changed and apart from some sampling options you are offered a 15 day free trial and then have to subscribe.
Graham
Master123456789
Posts 237
Yes vikinger - I have a subscription on deezer :)
And Fansastic - I cannot play deezer from the B&O app to my BV11
Any new suggestions? :)
Master123456789
Posts 237
Page 1 of 1 (10 items) | RSS
