BeoSystem 3 and SP/DIF without video source
This post has 1 Reply | 2 Followers
chrisped
Posts 5
chrisped Posted: Mon, Apr 9 2018 10:20 AM
Hi everyone, I hope some folks may have the right answer for me.
I have a BeoSystem 3 and I want to connect the audio only of my cable box digital out.
1) I have used a toslink to spdif converter:
https://www.amazon.com/Digital-Coaxial-Toslink-Optical-Converter/dp/B001622FL8
2) I have added the spdif connection to AV6 (linked it to Camera, set audio source to S-P/DIF, HDMI to D even though I have to HDMI cable connected to D, auto-selection set to "NO")
I dont get any sound.
My cable box is a Canal Digital box here in Norway.
I have also tried to connect the digital out (PCM) of my LG tv with the same result. / no sound.
What can I try?
One thing that worries me a little is the SPDIF cable (monster) has a large connector/plug (fat) and I am not sure if its properly connected to the BeoSystem 3 as the spdif female plug has only very limited space around it. Not sure if my explanation makes any sense. :)
Thanks, I hope someone here can help.
Christian
chrisped
Posts 5
chrisped replied on Wed, Apr 11 2018 5:07 PM
It was the cable that was at fault. My original cable plugs were to fat to properly fit into the spdif on the BeoSystem 3. :)
Page 1 of 1 (2 items) | RSS
