AV receiver for Beolab 17s and 18s
This post has 4 Replies | 2 Followers
dptrvt
Posts 4
dptrvt Posted: Wed, Apr 11 2018 1:33 AM
Hi all,
New member here, looking to be part of the B&O family. I never imagined I will be able to afford beauties like the 18s, but here I am.
I need to confirm if the Onkyo TX-RZ810 will work with the Beolab 17, 18 and 19s through the Transmitter 1.
Here is a link to the product sheet.
http://filedepot.onkyousa.com/Files/sell_sheets/TX-RZ810-NPR-US_4.5.17.pdf
Thank you.
neilgk175
Posts 14
neilgk175 replied on Wed, Apr 11 2018 2:22 AM
That onkyo will work just fine, you will need three rj45 to rca cables (front, rear, sub) to go from the transmitter to the rca preouts on the onkyo.
BV11-46, Beolab 3, Beoplay A1, A9, H3ANC, H8, H9i
neilgk175
Posts 14
B&O model number 6271216
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Hi dptrvt,
Welcome to Beoworld!  Yes, neilgk175 is correct, you need 3 x RJ45 to twin RCA cables to link from the pre-out sockets of this receiver to the Transmitter 1 for a wireless connection to 2 x Beolab 17, 2 x Beolab 18 and 1 x Beolab 19 speakers:-
https://soundsheavenly.com/bang-olufsen/rj45-powerlink-compatible-to-twin-phono-cable-output-from-new-bo-devices-to-amps-receivers-etc
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Barnetto
Posts 13
Barnetto replied on Wed, Apr 11 2018 10:11 PM
Good luck with the Transmitter 1. I had really bad issues with it in the year I had it and I had two in that time. It seems to have been down to 5ghz WiFi and WISA. My dealer sorted it with a new router using my old one in bridge mode and configuring the router to workwork in a higher band range.
I've since got the eclipse and have no issues at all but if you can, I'd advise hardwiring your beolabs or checking out the competition - there's a German company making a rival to the T1.
Beolab 18 (oak, white and walnut), Beolab 19 (white), Beolab 17 (aluminium), Beovision Eclipse 55, Beoplay E8 (charcoal sand), Beoplay H9i (black), a house full of Sonos, Synology NAS, Spotify user.
Page 1 of 1 (5 items) | RSS
