How to you get a fabric cover off, without damaging it?
Cant feel any movement, is there a trick ?
Want to repalce the cover with a new one, but cant see any tape or connector on the new front 1603676
Thanks Ken
What he said. But if you want the 500-word excruciatingly detailed answer, look in your duplicate post https://archivedforum2.beoworld.org/forums/t/30764.aspx
