What has happened to my Century
This post has 9 Replies | 0 Followers
Orava
Finland
Posts 991
Orava Posted: Sun, Sep 2 2018 4:41 PM
My Century does not work after removing from wall to isnpect door sensor.
Now after stand by mode when pressing any source, it starts like normal but suddently act like loosing power and returns at starting point. also no spin, no sound,  nothing...
Power relay do not act, but when contact shorted, it has power and amps are working.
Is there any known problems with Centurys?
Cheers
Orava
Finland
Posts 991
Orava replied on Sun, Nov 11 2018 11:14 AM
For a long time back with this. Can't find anything obviously.
It could be on for a half minute, then squeel and bang from speakers and shutdown (reset via loose of power?)
Any ideas?
Orava
Finland
Posts 991
Orava replied on Mon, Nov 12 2018 9:05 AM
Update. I tought amps were ok, left one probably is not because bumb is coming from it. Previously I did not have speaker connected, and did not hear it.
There is not current adjustmet on end darlingtons? Can I throw any pair there or not?
solderon29
U.K.West Midlands
Posts 764
solderon29 replied on Mon, Nov 12 2018 10:36 AM
It seems as though the unit is shutting down due to a "power fail".It could be due to one of the tweeters,or the output amplifier chip's becoming faulty?
What did you do to investigate the door system initially?
Nick
Orava
Finland
Posts 991
Orava replied on Tue, Nov 13 2018 8:22 AM
Did not much to investigate, removed frets and front panels to check sensor supply and functions, noting there, slight misplacement but not seriously.
Checked now with P14, amp power supply connector, off. Everything seems to work ok, so next step is to test if it is power  darlingtons (30v) or STK chips (15v).
Orava
Finland
Posts 991
Orava replied on Tue, Nov 13 2018 5:59 PM
Without 30v it works bit longer, so it is STK.?
Orava
Finland
Posts 991
Orava replied on Wed, Nov 14 2018 6:01 PM
No, it cant be.
solderon29
U.K.West Midlands
Posts 764
An  STK is the most likely culprit,but check the tweeters too,as they can become short circuit!
Nick
Orava
Finland
Posts 991
Orava replied on Tue, Nov 27 2018 12:57 PM
Finally with this again.
Looks like it is broken trace on power supply board, system on/off line from IC1.
Orava
Finland
Posts 991
Orava replied on Fri, Nov 30 2018 11:20 AM
Yes, now it is ok.
What a nasty and well hiding fault.
Just by accident found it when I was about to connect wire to testpoint, and noticed it is loose. In fact whole trace was more or less loose. Maybe recent house moving has something to do with this, Or agening circuit board. I don´t know.
Page 1 of 1 (10 items) | RSS
