My family recently inherited a B&O BeoGram 3000. I know very little about vinyl, and have only recently started getting into real records and turntables. I am looking to upgrade my current table but am not sure if I should purchase a new table or try and have the BeoGram repaired. It is currently not in working condition. I have a few questions I thought I would post to the forum to see if anyone can offer any guidance.
1) Is it worth it to repair this table? Like I said, I don't know very much about tables. Is this model (from somewhere in late 70s early 80s I believe) good enough to warrant trying to repair, or am I better off investing in a brand new table (either a B&O or something else like a U-Turn or Rega, which I've also heard good things about).
2) Does anyone know the specs for the table itself? Is it a belt drive or direct drive? Whats the w&f, and will these specs change if I opt to repair it (i.e. can the repair process itself alter the table).
3) Any idea how much a repair like this would cost? Even a rough estimate would be helpful.
Again, I don't know very much about this stuff but would appreciate any and all insight!
Thanks in advance!
Hello,
Without getting into the tech stuff around cartridge rebuilds and repairs in general, i would say, that since you have arrived here at the beoworld forum, it indicates curiosity around B&O, so you are in the right place for advice.
However, the most important thing for all beoworld members (apologies for generalising), are the love and respect for B&O products, so to ask if you should get it repaired/fixed, the answer is a definite YES!
In general, B&O products are keepers, especially if they are well kept. Get it repaired and use it and enjoy looking at it, when not in use. It is an easy sell (but not a goldmine), it if you decide you need something else.
I'm sure someone in here can be of assistance, either with a repair service or recommend someone that can - that is, if you decide not to do it yourself.
Beogram TX, Beovox S45, Beovox MC 120.2, BeoSound 1, CX50, Beovox S75, Beomaster 2400, Beomaster 5000, Beogram 5005
Depends on which 3000 really! Have had three of the 4 available and they were all great! The fourth is the tangential tracking one, which is also good but more light weight. The big advantage of something like a Rega will be cartridge choice - B&O cartridges are becoming scarce and expensive. However Beograms are very well made and can be serviced.
Peter
Peter: Depends on which 3000 really! Have had three of the 4 available and they were all great! The fourth is the tangential tracking one, which is also good but more light weight. The big advantage of something like a Rega will be cartridge choice - B&O cartridges are becoming scarce and expensive. However Beograms are very well made and can be serviced.
You're right, the cartridge issue is certainly something to consider. One huge advantage of most B&O tables is resistance to not only acoustic feedback but also to things like footfalls on wooden floors. If you live on something other than a concrete slab, walking across the floor will not upset a Beogram whereas a Rega will have issues. Plus, most Beograms are fully automatic, I for one got tired of having to get up to pick the arm up and turn the table off when I had a VPI HW19, the Beogram is a lot easier to use. I hope I can keep my tangential BG3000 running for a long time.
Jeff
