Happy New Year!
Nowadays more and more electronic thermostatic valves are available. Does anyone know if there would be any which could be controlled by beolink gateway?
Thanks for your thoughts
best regards
Elmar
I control my heating with Nest and use Domoticz software on a raspberry for home automation. I wrote a python script which interfaces the MLGW (probably the same for the BLGW) to the Domoticz software (using sockets on port 9000). Basically, once you have the BLGW interfaced to Domoticz, then you really can control a huge number of systems (see www.domoticz.com). It's open source.
The Nest Thermostat is fully supported directly in the BeoLink Gateway, including two way status feedback on the Web panel, IOS BeoLink app and on the TV's HomeControl menu, same thing goes for the Lutron RA2 wireless Thermostats
@beolinkapp
can you post a screenshot of the beolink app with the nest thermostat?
thanks
beoandy
BS Ouverture, BS 9000, AV 9000, Avant 32 DVD, BV9, BV6-22, BS 5, BS 4500, BS 7000, BC 9500, Beo6, BL Penta, F1000, BLGW, etc....
Hello!
Thanks for all your thoughts; what I would need - besides a wall mounted thermostat (like the nest, which looks really fine) - are thermostatic valves (hardware) mounted on the radiator; I'm living in a flat, there is a central heating in the cellar (district heating), only the property management has access; I do not have another heating-control only thermostatic valves...The pump runs all the day long; thats why I'm looking for a solution
Best regards
frog: I control my heating with Nest and use Domoticz software on a raspberry for home automation. I wrote a python script which interfaces the MLGW (probably the same for the BLGW) to the Domoticz software (using sockets on port 9000). Basically, once you have the BLGW interfaced to Domoticz, then you really can control a huge number of systems (see www.domoticz.com). It's open source.
Do you think that custom strings on the MLGW could be used to control Nest directly without using a raspberry pi? I would be interested in exploring this.
f5434964: Hello! Thanks for all your thoughts; what I would need - besides a wall mounted thermostat (like the nest, which looks really fine) - are thermostatic valves (hardware) mounted on the radiator; I'm living in a flat, there is a central heating in the cellar (district heating), only the property management has access; I do not have another heating-control only thermostatic valves...The pump runs all the day long; thats why I'm looking for a solution Best regards Elmar
Yes, you can usually add motorised heads to existing valve bodies, and these can either be wired or RF.
You would need some central control unit to talk to these (and the stats) but with the right setup it should be possible to setup communication between this central box and the MLGW.
It's something I'm intending to look into in more depth when I have some time - especially since our new boiler is opentherm compatible so there is the potential to control the boiler too.
Martin.
I don't think so as the interface to the Nest is via the Nest REST Apis. It's worth it to look into the Raspberry Pi/ Domoticz combo though as it opens the door to control everything.
frog:I don't think so as the interface to the Nest is via the Nest REST Apis. It's worth it to look into the Raspberry Pi/ Domoticz combo though as it opens the door to control everything.
You could look at Domoticz with Lightwaverf. Both for heating and lighting. You would need a lightwaverf gateway or a RFXTX433 transceiver to send the rf signals to the switches.
These work with Nest
https://workswith.nest.com/uk/company/energenie/energenie
Stoobie
Hi Chucky,
That suggestion was mainly for the first question. I also missed your questions in another thread re my TADO set-up. I'll go and answer there now.
I use Nest, but domoticz has Evohome support , though not through the RFXTX433, but by the evohome gateway.
Check out the wiki: https://www.domoticz.com/wiki/Evohome
I need the RFXTX433 for RTS on the blinds..... Really yet another one. The skylights work with IO also the blinds in the skkylights and the curtains with RTS, also in future for the gate I need RTS.
I could use RS232 for the RTS but that is more expensive.
