Mixing Powerlink Mk2 & Mk3 cables
nigelwilson
Posts 3
nigelwilson Posted: Sun, Apr 29 2018 9:31 PM
I have a Beovision 7-40 TV, a Beosound 9000 CDPlayer, a pair of Beosound 6000's , a pair of Beosound 8000's, and a subwoofer. I am now connecting up all these speakers using Powerlink cables. My question is this; I have some Mk3 cables and some Mk 2, can I mix these when connecting things up or do they all have to be either Mk2 or Mk 3 ? I appreciate any help you can give me. Thanks.
leosgonewild
Helsinki, Finland
Posts 2,373
The subwoofer needs Mk3 because of the icepower amp.
Your 6000 and 8000 most likely have the a/b amp, so you can use mk2.
Pat
Posts 152
Pat replied on Mon, Apr 30 2018 12:18 AM
If you have more mkII use them instead mkIII. PL mkII is better than mkIII because is fully mounted (8 x 8). You will not hear the difference but I would highly recommend mkII.
leosgonewild
Helsinki, Finland
Posts 2,373
Sorry, I mixed up mk1 and mk2.
Steve at Sounds Heavenly
The cable workshop, Leics, UK
Posts 2,165
Sometimes it can be hard to tell just by looking at an old Powerlink cable which version it is.  The link between the subwoofer (Beolab 2, 11 or 19) must be either a mk.3 cable, or a fully wired mk.2 that has pin 7 connected, otherwise you will hear a hum through the subwoofer.  The connections to the Beolab 6000 and 8000 speakers can be any version of cable due to their older amplifier technology, but newer cables will generally improve the sound.
If you need any help finding the right cables, please click on my sponsor link at the foot of the page and I will be pleased to assist.
Kind regards, Steve.
Steve.
www.soundsheavenly.com
Page 1 of 1 (5 items) | RSS
