Well, the inevitable has happened and my cartridge carrier has fractured, unfortunately with the 'tongue' firmly inserted into a newly repaired MM20CL which now flaps uselessly on the end of the arm.
I have read here that 3D printed replacement carriers are being made and are effective.
Is anyone in the U.K. offering an installation service for the cartridge carriers? Although I feel I ought to be able to do the work myself, I'm about to move house, so I'm not sure when (or if) I'll have the facilities & time to do so.
Thanks for any advice.
Adam K.
Hello,
Thank you.
Could you give an idea of the cost, please? Can you supply the 3D printed part, or should I buy one (from BeoLover?) for you to fit?
Hope the M150s arrived O.K., your courier seemed very good.
Adam.
