Another Beomaster 2400 question
This post has 24 Replies | 2 Followers
revkev8
Posts 3
revkev8 Posted: Tue, Aug 28 2012 1:58 PM
I was recently given a 2400 in very good physical condition. FM works. External heatsink runs very hot to the touch and has the notorious hum in the channels.
Worth repairing? I currently repair laptops and ipods. Should I look for a repair center or are parts available?
Thank you for any help.
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Tue, Aug 28 2012 2:03 PM
Absolutely worth repairing.
Replace the idle current trimmers and adjust to factory specs.
Standard and basic electronic components. Available anywhere.
Don't power it up again before servicing.
revkev8
Posts 3
revkev8 replied on Wed, Aug 29 2012 4:07 PM
Thank you. I must be living right. I just found another Beomaster 1900 at our recycling center. Except for a few lights out, works fine. Will keep this one and sell the 2400. Any ideas where to get replacement bulbs?
Dillen
Posts 13,191
Dillen replied on Wed, Aug 29 2012 4:17 PM
Yes Embarrassed
- but due to Beoworld regulations, we are not allowed to advertize our own listings on f.e. Bonanza...  Whistle
Søren Mexico
Mexico City
Posts 6,411
Dillen:
Yes Embarrassed
Member Dillen (Martin), can help you with lamps and other necessities for your BMs just send him a mail Laughing
Rich
Orlando, Florida, USA
Posts 2,598
Rich replied on Wed, Aug 29 2012 4:47 PM
revkev8:
Where do you live that people throw away BM1900s?
By the way, why not keep both?  I have both...
Søren Mexico
Mexico City
Posts 6,411
Rich:
Must be a country with no Ebay, bad internet, few connections to the outside world, BELIZELaughing
And yes keep both, if not for use, then keep one for spares.
revkev8
Posts 3
revkev8 replied on Thu, Aug 30 2012 4:26 PM
Must just be in the right place at the right time.
Thanks to all
holger_holland
Posts 13
These are the light bulbs specs for BeoMaster 1900 / 2400 en 2400-2:
Voltage: 12 Volt
Amperage: 80 mA
Wattage: 0,96 Watt
Fitting: T1 1/2
They are called micro lamps and you need 15 of them
In Holland they costs 72 eurocents. It cost me some afford to find the right specs so i want to let the world know
Dillen
Posts 13,191
Dillen replied on Tue, Feb 26 2013 6:24 PM
Welcome to Beoworld !
Happy to see a so eager new poster, no less than 7 almost identical posts. Being a moderator and technical advisor,
I have taken the liberty to answer two of them and delete the remaining since, unfortunately, they are giving out
wrong information like, sadly, most service manuals do.
12V lamps will be overrun in Beomaster 1900/2400 and will only last very few hours.
The original lamps typically lasted for 10-20 years or more, many are still burning, whereas owners who tried
fitting lamps bought from their local electronics store will keep replacing lamps at a steady rate.
You can buy the types made for chinese toys very cheap everywhere, particularly if you choose to go with
12V types, they are often found at less than 1 euro a piece (plus postage), that's correct.
Alternatively I can supply correct longlife types like the originals at the mere cost of production and postage
but the choice of what to fit in your Beomaster is yours completely. Smile
holger_holland
Posts 13
Dear Martin, Thank for your reply. I was so happy to find the right lamps that i would like to share this with everyone with the broken lights problem in their Beomaster 1900 or 2400
The lights i ordered are made in Germany (BMW en Volkswagen) en cost 72 eurocent each. So i'll give it a go and will let you know.
Thanks for being concerned.
Holger from Holland
holger_holland
Posts 13
Interesting: I just received an email of B&O theirself: They confirm the specs (voltage, watts, size, amperage) are OK.
Dillen
Posts 13,191
Dillen replied on Tue, Feb 26 2013 7:50 PM
holger_holland:
Interesting indeed but not a surprise since they probably just looked it up in the service manual.  Laughing
Would you care to share with us who at B&O signed the email ?
holger_holland
Posts 13
Yesterday I replaced al the bulbs. It was a little difficult to get everything in its place but my Beomaster 2400-2 is now working. I hope the lamps will last a long time.
Dus anyone knows the difference between the 2400 and the 2400-2 model. I'm very new with B&O.
14 days ago i bought my first beomaster and i really like it.
Dillen
Posts 13,191
Dillen replied on Sat, Mar 2 2013 5:11 PM
My experience from 35+ years of servicing these wonderful beasts is that the difference from
Beomaster 2400 to 2400-2 is minimal and mainly design related.
F.e. the lit icons on the frontpanel differs slightly but it doesn't seem to be a sharp transistion in that
some of the later Beomaster 2400 individuals already had the "newer" design.
Aad Jansse
Rotterdam (Neth)
Posts 236
Aad Jansse replied on Wed, Mar 13 2013 10:01 AM
Although I myself have a lot of sorrow as to getting my 1900's up and working properly I do know that a major difference between 1900 vs 1900-2 and 2400 vs 2400-2 is the volume control: 1-chip vs a 3-chip modification resulting in a 16 step vs a 128 step increase in volume.
By the way, does anyone know how to figure out the cause of one channel being dead? Does it make sense to begin with comparing the power IC's (TIP141/6)?
Dillen
Posts 13,191
Dillen replied on Wed, Mar 13 2013 12:23 PM
The volume control steps change was not related to the model name change. It took place during production
of the Beomaster 1900, that therefore exists with both volume controls.
One dead channel; Check the balance potentiometer. The bronze contacts often break off the black sliding bridge.
Beobuddy
Utrecht, The Netherlands
Posts 3,972
Beobuddy replied on Wed, May 29 2013 7:12 PM
Aad Jansse:
You should check things properly.
If you need help or some parts, I have several 1900's and 2400 at home. Feel free to contact.
Tobybgoode
Posts 4
Tobybgoode replied on Wed, Nov 11 2015 11:17 PM
I have a Beomaster 2801
The main dial indicator lamp, the one  that travels with the rotation of big alloy knob, is faulty.
The circuit diagram would suggest this lamp be rated at 12v but no clues as to mA or wattage.
Its a strange little lamp with just a pr. of wires poking out its end cap.
Can you supply.
Regards toby
Tobybgoode
Posts 4
Can you supply.
Regards toby
Tobybgoode
Posts 4
Can you supply.
Regards toby
Tobybgoode
Posts 4
Can you supply.
Regards toby
Dave Farr
France
Posts 2,283
Dave Farr replied on Thu, Nov 12 2015 7:22 AM
Toby, seems to be a quadruple post!
Martin aka. Dillen, normally has all of the correct lamps. It's better to contact him directly via his Bio page and send him an email or start a conversation as he can't follow every thread and may miss one.
Dave.
jhjortdal
Posts 1
jhjortdal replied on Fri, May 18 2018 3:16 PM
Hi Martin. I need a set of bulbs for a Beomaster 2400-2. Will you be able to supply ?
You are welcome to answer on my e-mail jhjortdal@energimail.dk and you don't need to do this in English :-)
Best regards Jens
Page 1 of 1 (25 items) | RSS
