BV4-50 and BSys2->BSys3
Stones
Posts 59
Stones Posted: Tue, May 8 2018 8:12 PM
Hi
I recently purchased av BV4-50 and BeoSystem 2. The set is HD ready only, but the monitor has the DVI input slot. Will it be of any benefit in picture quality to find a BeoSystem 3 mk1 having HDMI input and DVI output? Will this work perfectly?
Best regards
frog
Camberley UK
Posts 624
frog replied on Sun, May 20 2018 8:53 PM
Yes, of course the BS3 will work - and will add some extra picture processing - as well as source switching. The Beosystem 2 will only allow one DVI-bypass (you connect the STB directly to the screen.
Page 1 of 1 (2 items) | RSS
