Remote Control
DeaconBlue2016
Posts 78
DeaconBlue2016 Posted: Mon, Jun 11 2018 5:41 PM
Hi I have a 6500 set up with and MCP, which is fine.
Can use a hand held remote with the above set up and if so which Beo 4 (?) remote?
Regards
Dillen
Copenhagen / Denmark
Posts 13,191
Dillen replied on Mon, Jun 11 2018 10:49 PM
Beolink 1000
Beo4
Thomas
Norway
Posts 60
Thomas replied on Tue, Jun 12 2018 6:01 AM
Or you can use a Beolink 5000 (also two way remote).
Thomas
Format 0  😀😎
kallasr
Germany
Posts 2,562
kallasr replied on Tue, Jun 12 2018 8:19 AM
Just
Dillen:
Beo4
NOT the Beo 4 with the Joystick/Navigation button.
The one with SAT, CD, A.TAPE etc. was the "original" one.
Ralf
Guy
Warwickshire
Posts 2,590
Guy replied on Tue, Jun 12 2018 8:27 AM
If still using a turntable I would go for a BL1000; then you can access PHONO with just a single button press.
(Of course you can do this with BL5000 also, but they are a bit pricey and also quite fragile)
DeaconBlue2016
Posts 78
Ralf, thank you.
Can you tell me why?
Regards
DeaconBlue2016
Posts 78
I am using a T/T - Ralf suggests using the original one. Is this the one you refer to?
Page 1 of 1 (7 items) | RSS
