During Random mode, BeoSound 9000 MK II requires 'OK' to play music of next CD.
This post has 4 Replies | 3 Followers
siouxnil
Posts 2
siouxnil Posted: Sat, Aug 13 2016 3:14 AM
Professionally refurbished BeoSound 9000 MK II
Between every CD change during Random mode, the laser will properly move to the next CD, the new CD will begin to spin and display proper (random) track information, but music will not actually play until I physically press 'OK.'  This happens every time and is not intermittent.  Otherwise, everything else seems to be working normally.
Can someone please offer a fix?
Thank you
TrevorTron
Posts 6
Hoping someone might have an answer to this too, I also have a 9000 mk II with the same problem.
TIA
siouxnil
Posts 2
siouxnil replied on Tue, Jun 12 2018 3:46 PM
This problem is solved when the headphone jack is occupied.  Try putting an adapter in the headphone jack (as opposed to actual headphones).
For some reason, certain commands respond differently when the unit “thinks” headphones are in place.
TrevorTron
Posts 6
How very odd... but you are 100% correct!! Thank you so much for the prompt response. Well happy :-)
TrevorTron
Posts 6
How very odd... but you are 100% correct!! Thank you so much for the prompt response. Well happy  Smile
Page 1 of 1 (5 items) | RSS
