Dear all,
I have reset my Beovision 8-40 and all of the sudden it does not pair with my ouverture anymore (masterlink)!?
Tried al the beo4 option settings on both devices, but somehow they don't recognize each other....
Normally I pressed A-aux in the list menu, and I had sound from the laptop via the ouverture AUX input coming out of the speakers system on the BV8, now nothing after te reset...
Any help is appreciated!!
Kind regards!
Hi
Assuming you do not have external speakers connected to audio and just use TV speakers, the option programme should be:
TV = Option 2
Audio = Option 0
Then all commands are routed through the TV.
You could try selecting Aux manually on the Ouverture and see if you have sound through the head phone socket.
Check that you are using the Aux socket on the Ouverture and not one of the two Powerlink sockets.
Regards
Opman
