HELP!
Does anyone here know the speed of the motor 10M2: 8400126 in Beogram 3000 to 9500 and TX2?
These are no longer available as spare parts if I understood correctly, but maybe I have found a high quality replacement motor.
http://tinyurl.com/qj9cjsf
If you dont get an answer, measure motor pulley diameter, under platter belt run diameter, exactly, divide platter with pulley diameter x 33 1/3 or 45 and you have the the approximated speed
The motor itself I can't say but if you plan to replace the whole thing with electronic board etc. the speedobviously depends on the resistance put in between two control pins.
Thank you Sören and Martin.
